lenphotographic
Message 1 of 16
DRAYTEK 2860LN ROUTER
I was given the above router by work.  I have followed the instructions and although says connected to internet, it isn't. I think I may be inputting incorrect user name.
So my question is . With another router what username do I use and is the password the same as my original password  or is it the password on the back of the draytek router.
thanks
Len
15 REPLIES 15
Keith_Beddoe
Message 2 of 16
Re: DRAYTEK 2860LN ROUTER
@lenphotographic
Are you a BT Business customer?
lenphotographic
Message 3 of 16
yes
imjolly
Message 4 of 16
You need to post here  https://business.forums.bt.com/  As this is residential forum
lenphotographic
Message 5 of 16
hi
i am a residential customer. the router is in my house. not business phone line
imjolly
Message 6 of 16
Just you replied to @Keith_Beddoe  post are you a business customer  and you replied yes
now confused
lenphotographic
Message 7 of 16
i will start again. we had a draytek router going spare where i work so i took it home and want to install it instead of my bt hub router.
lenphotographic
Message 8 of 16
sorry didn't read the question you asked. I am a BT residential customer
licquorice
Message 9 of 16
Username is bthomehub@btbroadband.com and password is BT
lenphotographic
Message 10 of 16
thanks. i will try that.
regards
len
