lenphotographic
Message 11 of 16
Re: DRAYTEK 2860LN ROUTER
I tried that and it didn't work.  I get a WAN 1   IP address starting with 176. and according to the manual  its because the ISP has not accepted the username and password.
Any ideas.
len
imjolly
Message 12 of 16
The username and password are the same for all residential customers so must be something else setup incorrectly
licquorice
Message 13 of 16
If there is a setting for VLAN id, it should be 101.
aam
Message 14 of 16
Have a look at this:
https://www.draytek.co.uk/support/guides/vigor-2860-vdsl-setup
The screens and menus may vary a bit depending on the firmware version running on your router but on the whole it should be very similar to configure.
lenphotographic
Message 15 of 16
Hi
thanks for that. I upgraded the firmware last night so will have another go tonight. Frustrating when it should be so easy.
cheers
Len
lenphotographic
Message 16 of 16
Hi
Thanks for your great description. I updated the firmware and then followed your instructions. It worked.
I then set it up with Nord VPN as per draytek instructions and that worked too.
Cheers
Len
