Message 1 of 6
Deco M9 Plus
Hi,
Just installed a Deco M9 plus mesh with a Dray Tek vigor 130. I have not touched the 130 as it seems to be fine with the default settings (unless anyone knows different) for BT fiber. The M9’s (I have 4 to cover the house) also setup fine with everything up and running in under 5 mins.
The question is ipv6 is not enabled and I don’t know the settings, does anyone know? Also one PC is jittering every 2 mins going from 10ms to 3000ms and back to 10 again, any ideas for this as well?
5 REPLIES 5
Message 2 of 6
Re: Deco M9 Plus
Hi again,
Can anyone answer the previous question? I have tried multiple different settings to get IPv6 up and running but the M9 crashes every time and needs a full hard reset. Any help or suggestions welcome as this is driving me mad! My previous Archer AC2800 "just worked" as soon as I enabled IPv6 on the WAN.
Message 3 of 6
Re: Deco M9 Plus
BT use /56 Prefix delegation for IPv6, not all vendors support that, most only support /64PD.
What are the configurable options you have for IPv6?
Message 4 of 6
Re: Deco M9 Plus
I have the following Options
IPv6 : Enable or Disable toggle
IPv6 connection type : Dynamic IP, PPPoE, 6t04 Tunnel or Bridge
Dynamic IP > Get IPv6 Address : Stateful or Stateless and Obtain DNS Automatically Yes/No
PPPoE> Use Same Account as IPv4 Yes/No,  Get IPv6 Address : Stateful or Stateless and Obtain DNS Automatically Yes/No
6to4 Tunnel> Obtain DNS Automatically Yes/No
Bridge> Bridge Yes/No
I can enter DNS if Yes is selected
Message 5 of 6
Re: Deco M9 Plus
Enable
PPPoE
Stateless/Yes
Yes/Stateless/Yes
N/A 6to4 tunneling is a method of using IPv6 when native IPv6 isn't available, it just tunnels the IPv6 connection via IPv4
No
But it may still not work if the device doesn't support /56PD
Message 6 of 6
Re: Deco M9 Plus
Tried all the settings, but when applying I lose WiFi connection and when reconnecting it says wrong WiFi password? How would enabling IPv6 setting mess with the WiFi password. Just to be clear everything on the network gets booted off, I then have to hard reset the main Deco as I can no longer access the network. Any thoughts, might just bite the bullet and send the Deco back and get the Orbi as speaking to Netgear they have confirmed it now supports /56?
