tonyw1
Message 1 of 4
Deleting port forwarding rules created by UPnP - Smart Hub 6A - A solution.
I was searching these forums to find out how to delete some redundant port forwarding rules created by UPnP. The general consensus seems to be that a factory reset is necessary although it was suggested that some browsers might manage it, I could not find any listed.
If anyone's interested, I've found a browser that will delete these rules. It still shows a "no entry" sign when you hover over the red X, but if you click it regardless, Opera Version 12.17 will delete the little devils and although ancient, it's still available to download.
3 REPLIES 3
Message 2 of 4
Re: Deleting port forwarding rules created by UPnP - Smart Hub 6A - A solution.
UPnP doesn't create port forwarding rules, it just opens and closes the ports as necessary.
tonyw1
Message 3 of 4
SiFiUK
Message 4 of 4
I found out how to do this:
1) Click on "Show IP Address".
2) Press Tab (on keyboard) three times,
3) Press Return (on keyboard),
4) Confirm deletion of the rule.
