ToodlePeeps
Newbie
Message 1 of 2
Device not showing in Devices list
Hi all,
I'm trying to set up port forwarding for my xbox one, however cannot find my device via IP and MAC address from the drop down menu when adding the protocol. Is there any way to make it visible? It also doesn't show up in the devices menu under any category (wireless/wired/etc.).
Using BT Smart hub
Thanks!
Molly
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Device not showing in Devices list
@ToodlePeeps I'm sorry to see you're having issues setting this up.  Are you using the instructions as shown in this port forwarding guide?
Cheers
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
