DanThos
Message 1 of 1
Devices disconnected from Hub6
Hi
Seems like others, in the last 2-3 months WiFi on my Hub6 has been disconnecting devices and they cannot access WiFi again until the hub is reset. Before this it worked fine for nearly a year and now this is regular occurence, 2-3 times a week. The problem occurs with phones, tablets and laptops on both 2.4 and 5G SSIDs.  No new Access Points have appeared and I have tried changing channels.
 Not sure if this is new info but when devices are disconnected the following message appears in the event log
BR_LAN:The DHCP options that are offered by the device (id:53): DiscoverOptions: 53,61,57,60,12,55 | DiscoverOption55: 1,3,6,15,26,28,51,58,59,43 | RequestOptions: 53,61,50,54,57,60,12,55 | RequestOption55: 1,3,6,15,26,28,51,58,59,43 | HostName:  ********
 In the host name I can see different devices at the same time.
Does this help point a way at  a fix?
Thanks in advance
