Adnaan1
Message 1 of 1
Devices on access point keep disconnecting
I've purchased more than 5 different access points and each one of them have had issues with the BT home hub. I settled on a ubiquiti networks wireless access point and that has worked flawlessly for the past three months.
Recently devices will only be able to use the internet for 2 minutues before it disconnects and stops working.  I don't know if it's a DHCP issue or DNS issue, factory resetting the hub didn't fix the issue either.  Any suggestions 🙂 ?.
