Message 1 of 7
Differing speed up/downstairs
Evening all
I am having vastly differing speeds upstairs and downstairs. My downstairs speed is 127 and upstairs I’m lucky to get 20.
We had the now discontinued BT mini connectors so I’ve bought a new PLA and paired them in their place.
The speeds are still the same with the new PLA. I’ve also changed the plug socket the PLA goes in with the same results.
An engineer has visited and was convinced it was the PLA that was the problem and recommended which ones to buy on Amazon as the BT mini connectors have been discontinued.
The new PLA is still running the same speeds as the old…. Any suggestions?
Regards
Steve
6 REPLIES 6
Message 2 of 7
Re: Differing speed up/downstairs
Clearly a problem with your electrical wiring. I suggest you run an Ethernet cable.
Message 3 of 7
I have the Ethernet cables connected from both adapters, upstairs and downstairs. I’ve changed the cables to newer ones too.
Should I run a pat test on the sockets?
Message 4 of 7
No,  I meant an Ethernet cable rather than using PLAs.
Not sure how you would do that.
Anonymous
Not applicable
Message 5 of 7
@SteveDudd
I'm guessing that you have separate  electrical ring mains for upstairs and downstairs, and miniature circuit breakers, (MCBs), rather than wired fuses in your consumer unit?
PowerLine Adapters are known to not work so well when connected to different circuits.I think that it is because the signal that is being transmitted through the wiring gets attenuated by the coils inside the MCBs, and when the two PLAs are on different circuits, the signal has to pass through two MCBs - so gets double the attenuation?
Message 6 of 7
You are correct.
Is there any way around it or will I be better off going Ethernet as suggested above?
The problem only seems to be a recent one in the last 4/5 months. We’ve never had issues previously.
Anonymous
Not applicable
Message 7 of 7
@SteveDudd
"Is there any way around it or will I be better off going Ethernet as suggested above? "
Other than replacing the MCBs in your consumer unit with wired fuses, (to remove the source of attenuation), which is probably illegal with current wiring regulations, there isn't much else you can do other than run an ethernet cable, (as previously suggested).
If running a cable is probematic, have you considered if you actually need a wired connection - or will WiFi suffice?
If your device(s) is ethernet only, there are ways around that.
