eskimosound
Message 1 of 12
Digital Voice Question
So how do I set up my Hub 2 with my Digital Voice phone?
What lead do I need to plug into the back of my Hub 2 Digital Voice socket and where does it go?
Is it a special RJ11?
Tags (2)
11 REPLIES 11
eskimosound
Message 2 of 12
Re: Digital Voice Question
It seems it a BT431 to BT431 cable.
Can anyone please clarify.
barnpiece
Expert
Message 3 of 12
If you have the Digital Voice phone service, follow the instructions here:
https://www.bt.com/help/landline/digital-voice--how-do-i-set-up-my-service-
They work wirelessly using DECT (like other cordless phones).
You can plug a corded phone into the phone socket on the back of the Smart Hub 2.
Richard
licquorice
Message 4 of 12
Richard
As far as I'm aware, that socket won't work if you have digital voice, it is provided to connect to a copper landline.
eskimosound
Message 5 of 12
So how does my Digital Voice hone connect? Is it WiFi or Bluetooth? You can't plug the base unit into the landline....all you can do is plug the Smart Hub 2 into the landline using the Digital Voice socket
eskimosound
Message 6 of 12
Or could I plug a non digital phone straight into the back of the router using the Digital Voice socket?
licquorice
Message 7 of 12
Neither, it is DECT. There is a DECT base station built into the hub. Are you sure you have BT digital voice service or are you using a VOIP service.
eskimosound
Message 8 of 12
So they are just using VOIP technology...they've just called it Digital Voice?
RIC9380
Message 9 of 12
The socket on the HH does enable a traditional telephone to be plugged in and used (without the features that come with with the new DV handsets). I have a Gigaset DX800 connected directly to the HH.
eskimosound
Message 10 of 12
I've just bought the gear and need to swap over to digital voice, I was just looking and couldn't work out what the socket was for and if it used landline or the internet
