Message 1 of 3
Digital Voice and Home Hub usage
Can I install my DV Home Hub 2 (once it arrives) as a direct replacement for my existing HH2 (i.e.  for internet access) before DV activation date? Advice would be appreciated.
2 REPLIES 2
Message 2 of 3
Re: Digital Voice and Home Hub usage
yes you can install it as soon as it arrives to replace previous hub.  if you don't already do it I would change the SSID and wifi password on new hub to that of existing hub and save having to change all your wifi devices
Message 3 of 3
Thanks that's good news - and changing the SSID and password  is indeed my plan and previous practice!
