bananaman1
Message 1 of 4
Disable connection troubleshooter on Home Hub 4?
Hi,
Is it possible to disable the connection troubleshooter on the Home Hub 4?  I'd really like to disable it as I can't think of a single time I've seen it that it didn't cause me more inconvenience than the dropped connection it was trying to help me troubleshoot.
I found the following post from 4 years ago that says it was not possible to disable it back then but maybe something has changed in 4 years? I assume there have been firmware updates since so perhaps it's an option now.
https://community.bt.com/t5/Connected-Devices-Other/Disable-connection-troubleshooter/m-p/588590#M27...
It's not something that happens a lot but when it does happen it usually makes a bad situation worse so I really want to disable it if possible. I'd rather the router acted like a simple router and didn't interfere with traffc even if it thinks it is being helpful.
Hugh
3 REPLIES 3
Message 2 of 4
Re: Disable connection troubleshooter on Home Hub 4?
still the same cannot be disabled
bananaman1
Message 3 of 4
ok,thanks.
Message 4 of 4
No such problem with third party routers. Smiley Wink
