michael226
Message 1 of 12
Do I have a faulty hub 4?
Hi,
I've previously post about some problems with my HH4a - frequent restarts, frequent wifi disconnection, lots and lots of blocked entries in the event log never previously seen.
I've just experienced another issue and I'm now wondering whether a faulty HH might be responsible?
I have a PC connected via a cable to port 1.  The event log showed lots of lease requests and then 'host unknown (mac address removed) IP 169.254.xxx,xxx detected on interface eth0, port0'.   The devices showed on the network diagram as unknown but never appeared on the DHCP table despite refreshing.
Previous the PC had shown as a named device with the normal 192.168.xx.xx range IP address and appeared on the DHCP table.
Could all this and the other issues I have experienced be related to a fault hub?  Is it rare for one to develop a fault?
Any thoughts appreciated as i've had nothing but issues since receiving the hub a few months back.
11 REPLIES 11
Distinguished Guru
Message 2 of 12
Re: Do I have a faulty hub 4?
Home Hubs are cheap mass-produced things.  It's not unknown for them to develop faults.
A factory reset might help (or it might not).
michael226
Message 3 of 12
I've tried a couple of factory resets previously but still having problems.
Do you know how I might go about reporting a faulty hub and obtaining a replacement?
Thanks,
Message 4 of 12
phone customer services
08001114567
  Faults  0330 123 4567
michael226
Message 5 of 12
Thanks.  I'll give it a go.
One final thought before I do.   Whilst it's difficult to pin point, some of the problems (the frequent disconnects and invalid packets) seemed to have started when I was switched from interleaved to fast.   Is there an benefit in getting reset to interleaved first to see if this makes a difference?  If so, can I do this myself?
I'm still seeing lots of out block invalid packets in connection messages - including for odd websites I don't recognise.
Message 6 of 12
the blocking will be hub firewall doing its job not a problem
latency is automatic and fast is preferred for most people unless there are line problem but DLM would automatically change to interleaved
smf22
Recognised Expert
Message 7 of 12
As per my reply to your previous post on the firewall blocking.
To give an indication of what I was talking about, here's the list of servers my browser opens pages on when I go to https://www.youtube.com/
www.youtube.com 216.58.198.174
accounts.google.com 216.58.210.45
ad.doubleclick.net 216.58.213.102
apis.google.com 216.58.214.14
beacon.abba.accenture.com 198.101.184.237
cm.g.doubleclick.net 216.58.198.98
content.googleapis.com 64.233.167.239
fonts.gstatic.com 216.58.208.163
googleads.g.doubleclick.net 216.58.212.162
googleads4.g.doubleclick.net 216.58.213.162
i.ytimg.com 216.58.213.142
pagead2.googlesyndication.com 216.58.212.162
pubads.g.doubleclick.net 216.58.213.98
r3---sn-aigl6n7z.c.2mdn.net 173.194.5.185
r5---sn-aigl6n76.c.2mdn.net 173.194.5.203
r5---sn-aigl6n7s.c.2mdn.net 173.194.5.171
s.ytimg.com 216.58.208.174
s0.2mdn.net 216.58.213.166
ssl.gstatic.com 216.58.198.227
tpc.googlesyndication.com 216.58.213.129
www.google.co.uk 216.58.213.99
www.google.com 216.58.208.164
www.gstatic.com 216.58.198.163
yt3.ggpht.com 216.58.208.129
When you go to some other sites e.g., newspaper sites etc., the list goes on, and on, and...
If you use Chrome, install an extension called IPvFoo and you'll see for yourself how many sites your browser connects to.
Regards
michael226
Message 8 of 12
Thanks imjolly and smf22,
I just wondered whether the fast setting might be behind the frequency of disconnects, but will leave that to DLM.
The volume of Block events has got much worse since our last helpful exchange SMF22.  The firewall log often reaches its limit with 5/10 minutes!
I recognised most of the OUT blocks, but the most recent espiside was from the device IP address and are block going out to some very odd places/sites for example, 188.40.254.145 (hetzner), 107,181,19.70 (lighttower fibre) and 94.46.251.56 (nfsi telecom) which I cannot believe are safe or connected to sites we use.
PS, when I use YouTube the only out block recorded is to a BT IP address beginning 31.55.162.xx
Message 9 of 12
do you have parental controls active on your account?
michael226
Message 10 of 12
Sorry of the delay in replying.
I do have BT Net Protect enables to avoid changes to the DNS settings.
Would this be a possible cause?
Thanks,
michael.
