ipri
Message 1 of 4
Do I need this anntena?
Hi...I now have BT SF BBand...works fine. I removed previous router and an antenna before seting BT hub. I'm not sure what tha antenna did!...had 2 gold nuts which went into back of PC. Did this send out "Wireless" signals to other mobile devices in the house?...if so, should it still be in use? any info thanks.
3 REPLIES 3
Message 2 of 4
Re: Do I need this anntena?
if it was attached to your pc more like trying to receive a signal than broadcast one
Deathtrap3000
Recognised Expert
Message 3 of 4
It was probably the WiFi antenna for your computer.
ipri
Message 4 of 4
thanks...well...it's gone...and wifi seems to be ok .
