djw87
Newbie
Message 1 of 2
Do connections through BTWifi have the same public IP Address as a connection directly through hub?
My question is whether the public ip address of someone who is utilising my hub to conenct to a hotsport via BTWifi is the same as me connecting via my hub.
As I understand it, external connections through BTWifi will have a different range IPs assigned beginning with 10.xx... but does this apply to the private IP address and they will still be showing the same outward facing IP address that I would get if i did a lookup for my IP address?
Thanks in advance.
1 REPLY 1
Message 2 of 2
Re: Do connections through BTWifi have the same public IP Address as a connection directly through h
No they are different
