Guru
Guru
Message 11 of 26
Re: Does BT have a DNS server?
As well as your DNS settings in your router, you can also change them manually for the device your using too.
If you want the same DNS servers you have assigned the router too then just enter the routers IP address in the DNS primary nameserver field on your devices IP settings.
Otherwise enter the primary and secondary DNS servers on your devices ip config menu.
See http://www.howtogeek.com/167533/the-ultimate-guide-to-changing-your-dns-server/ (BT Retail has no responsibility over third party links and websites. )
Also if your using a PC then in cmd (command prompt) you could see if nslookup bbc.co.uk gives your the BBC's resolved IP address
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
YooHoon
Message 12 of 26
I dunno, I'm baffled
Message 13 of 26
why are you baffled it has been clearly explained
YooHoon
Message 14 of 26
Tried mostly everything and this stupid problem still perssists
Message 15 of 26
what problem are you having and why do you think it is a DNS issue
YooHoon
Message 16 of 26
Well when it happens and I run the trouble shooter, it gives me that windows cannot communicate with primary dns
Message 17 of 26
Which version of windows are you using
YooHoon
Message 18 of 26
Windows 8
Jonkarra
Expert
Message 19 of 26
If you have bt parental controls enabled at the network level that will block any dns servers other than BT's.
Rottie
Expert
Message 20 of 26
Have you tried OpenDNS as an alternative to the DNS servers you're currently using?
Primary: 208.67.222.222
Secondary: 208.67.220.220
I've been using OpenDNS for quite a while and I personally find that they respond faster than BT's or Google's DNS servers.
