Message 1 of 4
Does Smart Hub 2 cache things like images?
So work from home on websites. I have a real problem with images taking ages to load on the website I work on. I'm convinced that the Smart Hub 2 is doing some kind of cacheing which is causing me all links of problems.
Can someone tell me if it is doing it?
Secondarily how can I get it to stop? Or can I just exclude a domain?
3 REPLIES 3
Message 2 of 4
Re: Does Smart Hub 2 cache things like images?
No, it isn't caching anything, it's a router working at the IP layer not the application layer.
Message 3 of 4
dammit, was hoping that was the silver bullet I've been looking for. Thank you
Message 4 of 4
Caching is to help speed things up rather than slow things down. The problem if it was caching would be more down to stale data, e.g not reflecting an updated image.
Browsers will generally cache data unless the client has told it not to. Also web servers can tell the client or browser how long to cache the data for (check the response headers).
Use browser's developer tools to help track where the issues lies, looking at latency and if there's a common pattern between what you are seeing and the trace details.
