Message 11 of 11
Re: Does a repeater halve, or reduce the speed of the router it is connected to?
@licquoricewrote:
The wifi repeater will have no effect on an Ethernet connection directly to the hub, which you say is also a problem. It is more likely to be a problem with your line.
Agreed, if the repeater is using the same wifi channel as your router, as you seem to be saying, then yes it will approximately half your wifi speed but it will not affect either ethernet or WAN connection speeds
