thomasmulhall
Message 1 of 5
Does bt home hub support netbooting ie pxe server?
Hi im wondering does the bt home hub support netbooting (pxe server)
I would like to install ubuntu on a usb and plug it into the router so that i can host my own znc softwhere without paying to host it on a server.
So ubuntu will start up on the usb.
But i doint know how to install it or start it from the bt home hub.
Also does the bt smart hub support this too?
4 REPLIES 4
Guru
Guru
Message 2 of 5
Re: Does bt home hub support netbooting ie pxe server?
You might be best to buy a raspberry pi or small computer hardware instead to install the operating system on along with the software you need.
Otherwise a virtual machine may also work on an existing computer (i.e use of VMWare or equivalent)
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Message 3 of 5
@thomasmulhallThe hub cannot be accessed externally.
thomasmulhall
Message 4 of 5
oh, can i install znc on a usb and run it on there?
smf22
Recognised Expert
Message 5 of 5
You 'run' software on some form of CPU. What are you going to connect to the USB? It's probably not a CPU.
