js246
Message 1 of 2
Does restarting smart hub mean I need to also restart/reset Whole Home discs?
I’ve just restarted my smart hub (6) as there was a problem accessing hub manager. Should I now reset the Whole Hone app and run set up again? Also, if I want to try repositioning individual discs, do I need to run the set up again?
thanks
1 REPLY 1
Message 2 of 2
Re: Does restarting smart hub mean I need to also restart/reset Whole Home discs?
If all you have done is a "soft" reset, ie switched it off and on, everything should just re-connect again and there is no need to run the set up again.
