Message 1 of 9
Download Speed all over the Place, Upload Speed capped.
As far as I can recall since moving from ADSL to VDSL, i've had issues when gaming.....It's fair to say that the increases in speed have had a drastic influence on my ping/latency in games, causing lag and input delay.
I had better gaming connection using Wifi on ADSL than I currently do using VDSL on Ethernet!
What I can't understand with my connection, is why the sync speed on my router (Tested on 3 different Routers) is far higher than I can achieve.
Below are the stats of my router, and what my router is trying to Sync at.
I would also point out that those two 'Current Rate' figures are always fixed, and never change, whereas my Max Rate varies at least slightly, and the SRN Margin is continuously fluctuating.
Current Rate (Kbps)599739999
Max Rate (Kbps)845645838
SNR Margin (dB)88.4
Line Attenuation (dB)34.116.3
Errors (Pkts)00
BT Wholesale Speedtest
Test 1 -
Download Speed (Mbps): 23.85
Upload Speed (Mbps) : 5.17
Ping Latency (ms): 16
Test 2-
Download Speed (Mbps): 15.32
Upload Speed (Mbps) : 5.14
Ping Latency (ms): 12
Test 3 -
Download Speed (Mbps):31.28
Upload Speed (Mbps) :5.43
Ping Latency (ms): 13
Further Diagnostics Test
Test 1-
Download speed achieved during the test was - 30.82 Mbps
IP Profile for your line is - 38.67 Mbps
Upload speed achieved during the test was - 8.19Mbps
Upstream Rate IP profile on your line is - 10 Mbps
Test 2 -
Download speed achieved during the test was - 17.27 Mbps
Upload speed achieved during the test was -5.45Mbps
Upstream Rate IP profile on your line is -10 Mbps
I can't even run another test as it keeps telling me I must wait 10 minutes before testing again.....Even though i'm waiting longer.....
Followed by this error too -
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Using the Speedtest here brings up similar results.....https://www.thinkbroadband.com/speedtest
Test 1
Download - 33.1 Mbps                Upload - 5.1 Mbps
Bursting to - 35.8 Mbps              Bursting to - 5.3 Mbps
tbbx - 23.7 Mbps
Test 2
Download - 33.8 Mbps                            Upload - 5.1 Mbps
Bursting to - 34.9 Mbps                         Bursting to - 5.3 Mbps
tbbx - 18.9 Mbps
Test 3
Download - 20.8 Mbps                            Upload - 5.2 Mbps
Bursting to - 31.4 Mbps                          Bursting to - 5.3 Mbps
tbbx - 21.9 Mbps
(Ping was also constantly fluctuating from 15-50 ms during above tests too).
No wonder my Ping is extremely inconsistent and I get huge delay/slow inputs during games.
Would also explain why when I am watching streams/online videos they are always changing the quality.
All of the above tests were done Wired, with nothing else running on the connection, etc etc.
8 REPLIES 8
Message 2 of 9
Re: Download Speed all over the Place, Upload Speed capped.
So, I had a look around my router this morning, disabled both 'BitSwap' and an option labeled 'Disable AELEM'. Interestingly, that actually drastically changed my stats.
My Upload Speed SNR before hand, was labelled as 8 SNR, but is now labelled as 19.7 SNR.....Which I believe is far more accurate.
The Current Speed remains 5997 Kbps, whereas the Max rate is around the 14328 Kbps region.
Carrying out another BT Wholesale Test this morning, the results are still the same.
A fixed, but at the very least consistent, Upload Speed.
Whilst a low, and all over the place, Download Speed.
Download speed achieved during the test was - 23.59 Mbps
For your connection, the acceptable range of speeds is 27.5 Mbps-38.67 Mbps .
Upload speed achieved during the test was -5.65Mbps
Message 3 of 9
Download Speed falling below minimum guarantee!
Download speed achieved during the test was - 28.84 Mbps
Upload speed achieved during the test was -9.22Mbps
Router Stats
 UpstreamDownstream
Current Rate599739999
Maximum Rate1433545553
SNR Margin19.68.3
Line Attenuation34.116.3
Errors (Pkts)00
Is there anyway to increase the SNR on my download?
My current Download sync is far too high, it can't reach it, and it's no surprise that the fact the speed is all over the place leads to my line maxing itself out, producing ping spikes, when video streams keep changing their output quality.
Test 1 -
28.3 Mbps Download
tbbx1 - 28.5 Mbps
Bursting to 29.8 Mbps
Test 2 -
36 Mbps Download
tbbx1 - 34.8
Bursting to 37.3
Test 3 -
34.7 Mbps Download
tbbx1 - 27.2
Bursting to 35.4
Message 4 of 9
Re: Download Speed falling below minimum guarantee!
you look like you are on the essential package 40/10mb connection  as you are 40mb down speed you are getting as good as you pay for  the profile shown on btspeedtester is lower than connection speed to allow for overheads - same for everyone
enter phone number and post results    https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Message 5 of 9
@imjolly
According to your link, my minimum download speed should be 27.4 Mbps......
The speed is falling below that, regularly, so I'm not sure why you posted the link as all it does is prove my point?
Message 6 of 9
The dslchecker results shows connection speed not download speed  there is no guarantee on download speeds
post the checker results
Message 7 of 9
Message 8 of 9
@imjolly
Ofcom requires ISP’s (i.e. those that are members of its Speed Code) to attach a Minimum Guaranteed Access Line Speed (MGALS) to each line (you can request this from your provider), which reflects a similar definition of speed (see below). The MGALS speed is important because you can leave your contract (at any time) penalty free, provided your speed keeps going below the level it sets.
Ofcoms Explanation (MGALS)
If asked to explain further or asked to state the definition of “significantly below“, the ISP should provide information on the access line speed achieved by the bottom 10th percentile (or above) of the ISP’s similar customers (“the minimum guaranteed access line speed“) and explain that if the customer’s actual access line speed is below the minimum guaranteed access line speed, then it will follow the process set out in the 4th Principle.
A BTWholesale Spokesperson told ISPreview.co.uk:
“This process falls under the scope of Ofcom’s voluntary broadband code of conduct and relates to the value known as the 10th percentile speed for a given line. If the performance of an individual line falls below this speed, the CP is responsible for investigating whether there is a fault which needs to be resolved or whether the line simply cannot support greater speeds using the current technology. The CP should first investigate whether internal network issues are causing the slow performance on the line.
Should they find that a fault relates to the external network they should raise this with their wholesale provider. If after further investigation and remedial action the line is not able to support speeds higher than the 10th percentile speed, the end customer is given the opportunity to leave their contract free of charge.”
I'm falling significantly below the speed I should be getting.....
What is difficult to understand about this?
Message 9 of 9
Can't get beyond this screen now, unable to run the further test again......
Still way too low unsurprisingly.
