I am looking to replace my HHub6 with a Draktek Vigor 130 and Netgear Mesh MK62.
I can connect my Netgear to the HHub 6 and it works well but I want to use a Draytek Vigor 130 instead.
Can anybody help with what I need.
I tried to set the Netgear to IPv6 connection type of PPPoE and put in an Id of bthomehub@btbroadband.com with a password of BT.... and didn't change anything else but cannot get this to work
Any ideas?
Solved! Go to Solution.
Your user name is your primary email ie. mark@btinternet.com and password just put BT.
Thank you Stu
so just email and password of BT.
No other settings on either the router or the modem?
Modem should be plug and play and then you just need to go through the settings in router which apply to you.
Don’t forget, boot modem up first, allow a good 2 mins, then boot router and setup
No it isn't, completely wrong.
It is bthomehub@btbroadband.com
That’s strange, mines my email.
ive used that in my routers with various modems. I’m using a RAX120 at the mo.
I very much doubt it, the part after the @ is btbroadband.com not btinternet.com.
No, just looking at mine is btinternet.com And I’m using it now
perhaps it depends on age of account?
That really is weird as that was a common mistake people made using btinternet rather than btbroadband which prevented them connecting. Perhaps they have changed it recently to allow btinternet. The part before the @ never mattered.
