markgpowell
Message 1 of 27
Draytek 130 / Netgear Mesh MK62 Setup to replace HHub6
I am looking to replace my HHub6 with a Draktek Vigor 130 and Netgear Mesh MK62.
I can connect my Netgear to the HHub 6 and it works well but I want to use a Draytek Vigor 130 instead.
Can anybody help with what I need.
I tried to set the Netgear to IPv6 connection type of PPPoE and put in an Id of bthomehub@btbroadband.com with a password of BT....  and didn't change anything else but cannot get this to work
Any ideas?
26 REPLIES 26
Stu_H
Message 2 of 27
Re: Draytek 130 / Netgear Mesh MK62 Setup to replace HHub6
Your user name is your primary email ie. mark@btinternet.com and password just put BT.
markgpowell
Message 3 of 27
Thank you Stu
so just email and password of BT.
No other settings on either the router or the modem?
Stu_H
Message 4 of 27
Modem should be plug and play and then you just need to go through the settings in router which apply to you.
Stu_H
Message 5 of 27
Don’t forget, boot modem up first, allow a good 2 mins, then boot router and setup
licquorice
Message 6 of 27
No it isn't, completely wrong.
It is bthomehub@btbroadband.com
Stu_H
Message 7 of 27
That’s strange, mines my email.
ive used that in my routers with various modems. I’m using a RAX120 at the mo.
licquorice
Message 8 of 27
I very much doubt it, the part after the @ is btbroadband.com not btinternet.com.
Stu_H
Message 9 of 27
No, just looking at mine is btinternet.com And I’m using it now
perhaps it depends on age of account?
licquorice
Message 10 of 27
That really is weird as that was a common mistake people made using btinternet rather than btbroadband which prevented them connecting. Perhaps they have changed it recently to allow btinternet. The part before the @ never mattered.
