robartist
Message 1 of 6
Dropping wifi
My wifi keeps dropping. I have the latest BT adsl router.
I tried restarting router and resetting.
I tried different computers. Different browsers. But still got the problem.
But it happens quite often.
Any suggestions on how to get it working?
Thanks for any help
5 REPLIES 5
DavidM
Moderator
Moderator
Message 2 of 6
Re: Dropping wifi
Hi @robartist and welcome back.
Sorry you're having problems with your wifi connection. Have you tried switching off Smart Setup ? Have you tried splitting the channels? Take a look at How do I split my BT Hub's SSID (wireless network name)?
Cheers
David
robartist
Message 3 of 6
Re: Dropping wifi
Hi and thanks for reply. I have smart hub 2 so I think I can't split SSID name??
And yes smart setup is off.
Could it be a faulty unit? Thanks
DavidM
Moderator
Moderator
Message 4 of 6
Re: Dropping wifi
Hi @robartist,
Thanks for getting back. There's always a possibility it could be faulty. Is the hub in the same room as the devices you're trying to connect to?
Cheers
David
robartist
Message 5 of 6
Re: Dropping wifi
Yes in same room.
Also, everything has been working fine for months .
Anything else I can do?
imjolly
Message 6 of 6
Re: Dropping wifi
Try selecting the wifi channels manually instead of auto
i would use a wifi analyser on your mobile to see the networks about you and the channels in use and then select a free or less congested channel
