ccrocks426
Message 1 of 21
Editing anything in the router
Ok so I've noticed that if you login to the router and change anything e.g. portforward and then save it the router then restarts by itself and then stays orange for about 2 hours and then eventually works again
20 REPLIES 20
Message 2 of 21
Re: Editing anything in the router
Welcome to this user forum. @ccrocks426
I assume its the HH6 you are talking about, or is it a different one?
If its the HH6, then it could be an issue with line errors making it difficult to reconnect.
ccrocks426
Message 3 of 21
Yeah it is the hh6
ccrocks426
Message 4 of 21
If that is the case do you have any tips to help fix it?
Liam_
Expert
Message 5 of 21
What else makes the router restart?
Setting or removing port forwarding should not make the router restart.
Is your line noisy when using the phone?   Dial 17070 and select option 2, should be quiet between the announcements.
Message 6 of 21
Please do the following which may resolve this issue.
Reset the home hub to factory default.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Turn off Smart Setup
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Disable uPnP on the home hub.
Then configure your port forwarding rules again.
Also check for line noise as @Liam_ said.
ccrocks426
Message 7 of 21
The line is quiet and fine. I tried factory resetting it before and nothing happened, and bt also sent another router and it hasn't helped, and I'll turn off upnp when the router stops restarting
ccrocks426
Message 8 of 21
Nothing else makes the router restart
Message 9 of 21
uPnP could be trying to respond to portmap requests from applications running on your computer, at the same time as you are making changes yourself, which is why turning it off as soon as possible, is important.
ccrocks426
Message 10 of 21
Ok, I'm assuming it doesn't affect performance?
