Mike97
Newbie
Message 1 of 4
Engineer arrival date
Hello,
I have received a message when the engineer is coming to set up my broadband as I'm a new customer. It's around 4 weeks from now which is quite a while, I'm wondering is there any fee I could pay to speed up the process?
3 REPLIES 3
Message 2 of 4
Re: Engineer arrival date
No you can not pay to speed it up. You could phone BT and ask if the date can be changed. If you have no luck the first time keep trying and you may be lucky.
Mike97
Newbie
Message 3 of 4
Thank you, I hope so
Distinguished Guru
Message 4 of 4
The majority of broadband installs are now classed as self install. The engineer connects your line into the broadband network by running a jumper wire in the local PCP. You then just plug the router in.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
