redlegvpic
Message 1 of 5
Equipment return, need a jiffy bag please:
Hi, Could someone please get in touch, just want to get this out of the way, or confirm I can dispose of it?
Thanks Ian
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Equipment return, need a jiffy bag please:
Thanks Ian
How long have you had the item you are trying to dispose of?
See https://www.bt.com/help/tv/how-to-return-and-recycle-your-bt-broadband-hub-and-bt-tv-box-fo
redlegvpic
Message 3 of 5
Thanks for the prompt reply, believe it was 2016, changed to Halo3 May last year.
Ian.
redlegvpic
Message 4 of 5
Hi, This link is maybe out of date, there is no "return equipment" tab, is it possible to have a returns bag sent to me?
[If you need another bag or need one sending to a different address, you can order one easily by logging into My BT and selecting 'Return equipment' under 'Return your BT kit'. ]
Many thanks Ian.
NeilO
Moderator
Moderator
Message 5 of 5
@redlegvpic I'll be able to help you with that, you'll get a private message in a moment so you can send over your details.
Neil
