on 01-07-2018 20h16
I’ve recently swapped from standard to fibre broadband. My new hub has arrived. Do I need to change the Ethernet cable or am I ok to use same 1 from my standard hub?
Solved! Go to Solution.
on 01-07-2018 21h09
You can use the same one.
