Message 1 of 5
Extend broadband using cat5
Hi I have set up cat5 cabling in house and intend to move where the router sits, away from phone socket. I have run a cat5 cable towhere the phone/broadband socket is as per electrician advice with other end being where I want to have the router. Can anyone help with what I need to do to connect cat5 to the bt socket? Thanks!
4 REPLIES 4
Message 2 of 5
Re: Extend broadband using cat5
You don't need cat5 cable to simply extend the incoming broadband signal. You just need 2 wires connected to the data extension terminals of the master socket and an rj11 socket at the remote location.
Message 3 of 5
Thx. Given I have now put the cables in the wall to another room, ‘can’ you use cat5 eg any way to connect using an adaptor? I can’t now put the phone line cable in the wall….
Message 4 of 5
Given I have to crimp the rj45 heads on, if I crimp an rj11 head on instead and leave some wires redundant, would this work….? Thanks
Message 5 of 5
Of course, you just need to use one pair. The cat5 will come in handy if/when you get FTTP and the ONT is sited where the master socket resides. You will then need Ethernet between the ONT and hub.
