leemmcc
Message 1 of 3
Extended the wifi with an old Netgear router.
Hi,
I'm trying to set up an old router as an extender to help with WIFI signals in parts of the house. My main point is the BT Smart Hub - Type A I got from BT. I want to use a Netgear WNR3500L as a repeater (or however is best to extend it).
https://kb.netgear.com/2745/How-To-Set-WDS-Repeater-Function-on-WNDR3300-WNR3500
I've followed the guide here of how to put the router in repeater mode. The problem I've got is I can't figure out what to do at BT Smart Hub side? The Router SSID appears but I can't get an internet connection from it.
Can anyone suggest what to do or give guidance? I've probably got something configured incorrectly.
2 REPLIES 2
bratman91
Message 2 of 3
Re: Extended the wifi with an old Netgear router.
I tried this with a TP-Link router (https://community.bt.com/t5/Home-setup-Wi-Fi-network/Using-TP-Link-W9970-router-as-Access-Point-to-H...) and eventually managed to get it to work. However, the setup was so flaky and resulted in so many IP errors with my iMac that I gave up. Maybe you will have better luck with a Netgear router but my advice is to bite the bullet and buy something designed to do the job. I bought a BT 11AC Dual Band N1200 WiFi Range Extender from Fleebay for £21 and it works well - you might be able to get something cheaper.
leemmcc
Message 3 of 3
I had a feeling this what be the case.  To be honest, I think I'll just do what you did as I can't have packets dropping randomly.
Thanks!
