the_saucerer
Message 1 of 5
Extending WiFi signal upstairs
I have BT Inifinity with Homehub 3. I need to get internet to a new computer in eldest's bedroom upstairs. The signal from the homhub doesn't quite reach.
I spoke to BT and they said get a repeater. They said don't get a powerline adapter.
I have been looking at both particularly the latter with another router plugged in but am still unsure which route to take.
I hope someone can offer some advice as to what th best thing to do to get a decent signal upstaris.
Thanks in advance
Ben
4 REPLIES 4
Message 2 of 5
Re: Extending WiFi signal upstairs
Powerline adapters are fine.
These pages should help.
Network connection problems and possible solutions
the_saucerer
Message 3 of 5
Thanks for your reply. Is it plausible to plug a router into the upstairs powerline adapter?
Message 4 of 5
Do you mean a wireless access point, or something to increase the number of Ethernet connections?
All of the options are discussed on the web page link I gave you.
the_saucerer
Message 5 of 5
Yes a wireless access point, I have seen what I was looking for now thanks for your help Smiley Happy
