StaffsBob
Newbie
Message 1 of 3
Extending fast broadband connection to garden office
Hi,
Which is the BEST way of supplying a FAST connection from a home hub on fibre broadband, to a garden office approximately 20 metres away from where the hub is positioned? The office will need the lions share of the connection during the day. Should I connect via a wired connection over this distance, by means of a plug in extender, or through whole home wifi adapters?
Thank you.
2 REPLIES 2
Message 2 of 3
Re: Extending fast broadband connection to garden office
Ethernet cable is the best option with powerline extenders if on the same ring main second.
prinknash
Expert
Message 3 of 3
I agree with @licquorice.
My situation was slightly different in that wifi from my router (upstairs, front of house) wasn't reaching into my garden (downstairs, back of house). I solved it by using a powerline extender downstairs plugged into a spare router used just as a wireless access point. I now get excellent coverage throughout the house and garden although it does require selecting a different wifi source as necessary - but that's no great hassle.
p
