pennyuren
Newbie
Message 1 of 7
Extending range of home hub
Hello all
i want to extend the range of my home hub so that it covers the upstairs room of our detached garage which is about 15-20 metres away from the home hub sat in the hall of our house. any advice on how i can do this as cheaply as possible as it is only a temporary measure for a few weeks while son is home from university and working on a project up there in peace.
thanks
6 REPLIES 6
Message 2 of 7
Re: Extending range of home hub
This link shows one alternative.
Increasing wireless range using a TP-Link TL-WA701ND
A more reliable method would be to use a couple of powerline adapters, provided his computer has a network (LAN) port.
What are powerline devices and how do they work?
Search for TP-Link TL-PA211KIT AV200 Nano 200Mbps Powerline Adapter - Twin Pack
Dean235
Message 3 of 7
Powerline adapters only work if they are on the same electric circuit and not segregated.
Amazon UK shows a varitey of results
Oranda
Message 4 of 7
Keith
Your link refers to using the HH3, does the TL-WA701ND work with the HH4 as a wireless repeater as I am struggling to get coverage throughout the house with my new HH4.
Oranda
Message 5 of 7
Bump - has anyone else used this repeater with the HH4. Keen to find out if it works OK before I order one.
Oranda
Message 6 of 7
Well I took the plunge and ordered a TP-Link TL-WA701ND.
It works fine as a repeater with the HH4.
Thank you Keith for the instructions on your website. Worked a treat, up and running in less than 5 minutes.
Tags (3)
Message 7 of 7
Thanks, that is useful information. I could not see any reason why it should not work with the HH4.
I am sure your comments will be helpful to others.
