SA_2012
Message 1 of 8
External Hard Drive with BT HOME HUB 3
I have an external hard drive of about 500 GB which I want to attach with BT HOME HUB 3 and share its contents (movies etc) with other computers attached to the BT HH3 (wireless).
I have windows 7 installed on all the laptops if that makes any difference... could anyone please guide me how I can have the hard drive over the home network throught BT HH3.
Thanks,
7 REPLIES 7
Deathtrap3000
Recognised Expert
Message 2 of 8
Re: External Hard Drive with BT HOME HUB 3
\\192.168.1.254
type that into a windows explorer folder window.
Message 3 of 8
@Deathtrap3000 wrote:
\\192.168.1.254
I think you mean 192.168.1.253, as that is the USB port.
Deathtrap3000
Recognised Expert
Message 4 of 8
no i mean 254 as its the hub which is sharing the usb device that your trying to connect to
\\192.168.1.254
SA_2012
Message 5 of 8
....thank you everyone for replying to my post.... I have tried the number and it works for a normal USB (4GB) but when I attach the 500 GB, it doesn't bring anything ... any idea why...?
Davvidof
Message 6 of 8
Does it only work with a drive that is formatted as 'fat 32'  I tried it with mine and it is 'ntfs' and was not recognised?
SA_2012
Message 7 of 8
The memoray stick which worked was formated as fat32 but the external hard drive is not. I tried to reformat it to fat32 but my computer doesn't give me fat32 option...may be its the windows 7 thing... or may be its something with the hard drive.... anyways, I will try to format it with a computer running an older version of windows to see if that gives me an option of fat32 format...  will write again later...
Deathtrap3000
Recognised Expert
Message 8 of 8
Theres a free program you can download on win 7 that can format to fat32. Forgot what its called though. Google will help you.
