Devon_Dave
Distinguished Guru
Message 1 of 4
External WiFi antenna setup with access point.
OK expert's perhaps you can advise.  My current setup is I have a tplink 701 wireless access point with an external antenna with a good amount of gain out in the garden.
This is only rated at 150Mbps. I am looking to upgrade the WAP to something like a 901. Other than the speed the other difference is that the current 701 only has 1 antenna so currently not an issue however the 901 has 3 antennae, but would only be extending one. L
The only issue I can see would be antennae diversity.
Thoughts anyone?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: External WiFi antenna setup with access point.
@Devon_Dave
You would not be able to use that with an external antenna. I would have thought that 150Mbs was more than adequate for most wifi devices.
I think you will also find that there are no external aerial connections on the 901. The 701 was designed for that.
Devon_Dave
Distinguished Guru
Message 3 of 4
Keith. Thanks for your thoughts and comments. I've just watched a YouTube video of a guy setting up a 901 and it does appear that the 3 antennae plug into the back of the WAP. So there are 3 separate sockets.
Keith_Beddoe
Message 4 of 4
I must admit, I have not looked at the 901, but I have a couple of unused 801s, and the two aerials are fixed, so maybe the 901 is different.
I would try a speed test just to see what speed you are getting, as interference on the wireless channel can have big impact.
I assume there are no other buildings in the garden, with power, which you can use to improve things?
I now use a Tenda Nova MW3  four node wireless mesh to provide coverage inside and out, but have power in the garage for one of the nodes.
