Message 1 of 2
Extra wifi disk
Hi hopefully someone can help
I seem to be going around in circles with the troubleshooter, and I can't ring up as using the phone is difficult for me. (disability reasons)
I need to order two extra wifi disks as we are in a big house with stone walls which has lots of black spots. There must be some way of ordering these without having to ring 150.
I can't seem to find a way of doing it?
1 REPLY 1
Message 2 of 2
Re: Extra wifi disk
phoning CS 03301234150 is probably quickest but you could try message now and see if that helps
https://www.bt.com/help/contact-bt/technical-support/broadband
