Message 1 of 3
FTTC ethernet connection using ethernet switch
I am buying a new TV my BT line is FTTC .ethernet cable conncetion I will have to buy an ethernet switch as the inputs on the smart hub are full. Is this likely to give an acceptable result? BT will not provide an FTTP service where we are in Ipswich so end of contract will probbaly move  a provider that will
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: FTTC ethernet connection using ethernet switch
A switch will be fine but try WiFi first, it may save you the expense & wires.
Message 3 of 3
Thanks for the prompt reply
