michaeljpower73
Message 1 of 8
FTTP 900 Service and Draytek Vigor 2860AC - Settings
Hi All,
I have just moved from Virgin Media 350 to the BT FTTP 900 service - it's a pure fibre connection.
I am connecting from the ONT to my Draytek Vigor 2860AC but can't get the right combination of settings. Has anyone there managed to crack this?
The username I have is the right one having checked with BT and also is what is showing on my Homehub.
Any help or advice appreciated.
Mike
Tags (1)
7 REPLIES 7
licquorice
Message 2 of 8
Re: Hi FTTP 900 Service and Draytek Vigor 2860AC - Settings
The only settings you need are PPPoE username of bthomehub@btbroadband.com and password anything but BT is usual.
I suggest you factory reset the Draytek, if you didn't already do so, before setting it up.
michaeljpower73
Message 3 of 8
Thanks - I reset the router, went through the set up wizard to ensure I can clean as a whistle and used those credentials and no connection unfort. All still red...
That router should be compatible I am sure. Any other ideas - I have tons of experience of other routers but not this one in particular.
licquorice
Message 4 of 8
Sorry, I have no experience of the Draytek, but shouldn't be any different to other routers. Is there a setting to select between modem/router mode and router only mode, perhaps it is defaulting to DSL input rather than WAN input.
michaeljpower73
Message 5 of 8
No worries... Have tried so many settings now it's making me dizzy..
michaeljpower73
Message 6 of 8
Last config screen
Any help from anyone appreciated 🙂
licquorice
Message 7 of 8
I have to say the settings look as though it is expecting a DSL signal but without having access to the GUI it is difficult to know. You somehow need to select WAN2 as the input rather than WAN1 I think.
I suspect WAN1 is the logical WAN port for the physical DSL port whereas WAN2 is the input from a modem (ONT).
michaeljpower73
Message 8 of 8
Legend status!
Hadn't spotted that at all....... It now connects perfect..
Just few more steps to figure this out so it connects with my Mesh wifi system but it's connected.
