Message 1 of 5
FTTP, Super Hub 2 and M9 Deco Plus
I'm about to rejoin BT and since I was last with them I've acquired 3 Deco M9 Plus pods for a mesh network which works perfectly with my current provider (VM). Moving to BT will mean using the Fibre to property box and have a box that I can connect straight into.
Moving to BT will give me the Super Hub 2 but do I need this if I'm running my network off the M9s? Can I connect an ethernet from the FTTP  box directly into the M9 and completely bypass the router?
Would I need to change any of the settings on the M9? I also rely on port forwarding so would this still be enabled?
4 REPLIES 4
Message 2 of 5
Re: FTTP, Super Hub 2 and M9 Deco Plus
You will need to use the SH2 if you require a voice service as Digital Voice is only available via the SH2.
Otherwise you just need to enter the generic PPPoE login details of username bthomehub@btbroadband.com and password BT on the M9 and connect it directly to the ONT.
Message 3 of 5
Nice one, thank you.
I don't think Ill need Digital Voice but in the event I do,.can I still use the M9s connected to the SH2?
Message 4 of 5
Yep. You will be "double natted" which may or may not be a problem for you.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 5 of 5
Hi - Can I double check that the Deco M9 Plus will negate the need to use the BT hub, connect directly to the mini OLT, and also work with BT TV?
I ask as  I've seen a customer post saying that the Deco M9 plus doesn't allow for BT TV. Something to do with 'IGMP proxy or snooping capability'.
Thanks!
