Message 1 of 2
FTTP and WiFi Options
Yesterday I got upgraded to Fibre 900 which was a smooth experience and everything is working as expected.
As has been commented elsewhere in the forums, I get 900+ on a Speedtest using Ethernet,  but on WiFi I get a download around 380.  I have a Hub 2 and the original Whole Home WiFi extender discs.  My question - is there a better hardware set-up?  Will the more recent models of WiFi extender discs give me a higher speed or do I need to wait for the rumoured Hub 3?
I am tethered to the Hub 2 as I have BT TV.
1 REPLY 1
Message 2 of 2
Re: FTTP and WiFi Options
You don't have to use the Hub2 with BT TV. You do need to use the Hub2 with Digital Voice though.
I have no idea why you need more than 380M on a single wifi device
