Barnsley
Message 1 of 3
Few questions
Got my broadband upstairs all connected
A few questions if ok
Do I need to do anything else security wise or is it all configured?
I've decided not to have bt virus protect as I have a anti virus on my pc already
Also my broadband signal downstairs on my sky configuration so can connect to Wi-Fi only has a 56% connection strength signal, I will need to use it for Alexa too. Is 56 % ok?
2 REPLIES 2
Message 2 of 3
Re: Few questions
Nothing you can do on the Hub.
Good thinking!
Try it and see, all you can do. If it is problematic, there are solutions.
Barnsley
Message 3 of 3
Re: Few questions
My Wi-Fi in the room below with all my tv's etc is only 60odd percent but in my kitchen it's full
BT said there are white pods I can get(I'm guessing they're not free) so Wi-Fi will be strong in every room, surely I don't need that I'm only in a small house. My old ISP was fine?
