Message 21 of 26
Re: Fiber1 on BT Hub6 - Issue connecting to NHS VPN (Global Connect)
@licquorice thanks for not calling me a fool.
All working a treat.
Time to check the VPN. 🤞
Message 22 of 26
I almost can't believe it as I just don't understand how it could have been causing the issue, swapping the router has resolved the problem 🥳
Thanks @licquorice @Keith_Beddoe @Anonymous for you advice and support. 👍
Message 23 of 26
@hcarpe1977
I am pleased you have it sorted, you are not the first to have problem with VPNs on the home hub.
That router also has QOS controls, should you need to allocate a higher priority to some devices.
Anonymous
Not applicable
Message 24 of 26
Question now is whether the Smart Hub is faulty or has a generic issue. It might be worth trying to get your hands on a SH2 to test, bearing in mind that if you're moved to Digital Voice you will be forced to use one. Would give you time to plan & test options before potentially having to make a choice between a working VPN & a working landline!
Message 25 of 26
As it happens, following my very frustrating call with BT 'support', I am expecting a new Hub6, so I'll be able to test and see if it was an issue specific to my Hub6.
I will let you know when that arrives and I've tested it.
Anonymous
Not applicable
Message 26 of 26
Bear in mind it will likely arrive with old firmware that will automatically update at some point. So if it works out of the box, don't be in too much of a hurry to return the the TP-Link until you've seen the firmware updated in the log.
