Keiran_Ledicott
Message 1 of 2
Fibre Line Installation
Hi,
The flat i have just moved into only has copper wires and it is right at the edge of town centre which all has fibre. The whole street apart from the private area at the end which is the part of the street that I have moved into has Fibre WiFi. I have asked everyone in my block of flats and they all want Fibre WiFi as well. How do i got about contacting an engineer to see if he could install the Line for the Fibre WiFi.
Sincerely,
Keiran Ledicott
1 REPLY 1
JohnC2
Moderator
Moderator
Message 2 of 2
Re: Fibre Line Installation
Hi @Keiran_Ledicott welcome to the forum and thanks for posting. You can check what is available and place you order via https://www.bt.com/broadband/deals
cheers
John
