newja
Message 1 of 3
Fibre Smarthub - WPS not working
Hi, today I have had my Fibre instal and all is going well in many areas but there are a couple of things not working out right so I shall post 2 separate questions.
I can connect using the password and all well there BUT if I try and connect my wireless HP printer via the WPS method (which has worked on every other hub "just like that") I get a WPS timeout error at the printer and the WPS button keeps on flashing.  Yes, I can turn it off in the advanced settings but I guess I am perhaps seeing this as an error but not sure whether it is something that I need to do differently OR an error with the Smarthub6?
Any ideas please let me know, thanks!
Tags (3)
2 REPLIES 2
imjolly
Message 2 of 3
Re: Fibre Smarthub - WPS not working
You would have been better keeping both questions in one post
smart setup turned off?
newja
Message 3 of 3
I kept them separate in case a solution came along that solved one and not the other!  Wishful thinking eh?
So I have turned off "smart setup", saved and retried both issues twice - no joy, thanks anyway!
