hurleh
Message 11 of 13
Re: Fibre optic help
Yep this is the exact problem 😞 I wonder what randomly caused this, you think they will resolve it soon and fix it ? as it says January 2019 which was roughly when mine started too.
I have a Netgear router which has QoS but it really doesnt do anything or im just not using it right,
I put my console to about 30% Bandwidth allocation so it gets more correct and put the device that is taking the bandwidth (one using netflix) put this down to about 5% upload allocation or should I be allowing it to have more or what? Not really sure
Hope this gets fixed soon
hurleh
Message 12 of 13
Anyone know if there is anysort of fix at all?
hurleh
Message 13 of 13
Keeping this on the front page so BT can see everyone having this problem and fix it
