paulspencer
Message 1 of 6
Firmware Updated doesn't happen
I have BT whole home wifi.  In the app it says that two of my discs need a firmware update.  If I click 'Update firmware' I then get to a page that makes me hit 'OK'.
I get a spinner, and the spinner goes away.
But the app still says that I need a firmware update.
I've turned everything off and on.
How do I get the firmware update working?
5 REPLIES 5
paulspencer
Message 2 of 6
Re: Firmware Updated doesn't happen
For the record in 'Disc Details' it says that the firmware version is:
v1.02.01 build22
The problem could be that the firmware is correct but the app is incorrectly reporting that it needs to be updated.
Moderator
Moderator
Message 3 of 6
Hi @paulspencer and welcome.
I have updated the firmware but the app is telling me an update is required for one the discs? should help so can you take a look and let me know how you get on?
Cheers
David
paulspencer
Message 4 of 6
That didn't work.
That description assumes that I have one near the router, with ethernet, and one remote without ethernet.
In this case both are connected directly via ethernet to the router.  I have an office in the garden and have an ethernet cable to it from the router.  So I have my office disc and my hallway disc, both connected by ethernet cable to the router.
Any ideas?
Do we know what the current firmware version is?
paulspencer
Message 5 of 6
How rude of me!  I forgot to thank you for responding at all!
That article looked right on the button, sadly it didn't seem to work.
THANKS
Moderator
Moderator
Message 6 of 6
@paulspencer I'm sorry that hasn't worked, it might be best to get in touch with the whole home wifi help desk directly to see if they have a solution for this.
By phone: 0808 100 6116
Monday to Friday 9.00am to 5.30pm
Saturday 9.00am to 2.00pm
By email: btconnectedhome@bt.com
