rjh123456
Message 1 of 1
Fix for those with FFXIV ARR throttle problrms
FIXED IT
I have fixed my BT throttle problem by simply forwarding the ports in the router
please see the following guide for what to do (it's very easy)
http://portforward.com/english/appli...l_Fantasy_XIV/
http://portforward.com/english/appli...asy_XIV/BT.htm
http://portforward.com/english/route...antasy_XIV.htm
This will work if you do it correctly (don't mess up the TCP/UDP, and forward all ports)
I hope it works for you guys, it did for me
