LCourtney
Newbie
Message 1 of 2
Fixed IP to connect why?
In order for our internet to connect to iPads phones laptop they need to be set up with a fixed IP address, this is causing me problems when I try to get on the internet with my work computer, I do not have admin rights to fix the IP address but why should I have to? Is this something that is wrong with our router? I need to work from home and find this infuriating as sometimes it works without fixing the IP address but of course the night I need it to work it doesn't. Any help much appreciated.
1 REPLY 1
vofsanity2
Recognised Expert
Message 2 of 2
Re: Fixed IP to connect why?
Please tell us the type of router you are using (eg 3 A or B, 4 B, 5 A or B) and the broadband package you are on (Eg Adsl, Infinity 1 or 2 etc) and any other information that may be useful eg version of windows on your Work Computer.
You should not be having this problem and we need to determine whether the router has a problem or your setup is at fault.
