Message 1 of 1
Force Whole Home disc to use wifi connection.
Hi,
I have the orginal white whole hub system with 6 discs.
I want a connection in our garage but as it is too far away a disc to disc connection will not work.
I have a Ethernet link to the garage but not to the room where the man hub is.
My working solution is
HUB > Disc > via wifi > disc 2 > via ethernet > disc 3 (in garage).
n normal circumstances this works but if we have a power cut of broadband to house goes down (this does happen too frequently) the disc 2 defaults to want to take its signal from the plugged in Ethernet port. But this is connected to the garage disc which now has no internet signal.
Is there a way I can force disc 2 to only take its internet connect from wifi not default when powered up to take it from the cable.
I currently have to reset the system by unpluggng disc 2 waiting for it get a wifi signal then plugging in ethernet cable to send signal to garage.
It only takes a 5 sec drop in internt signal for link to garage to stop even though the rese of the house resets automatically. very annoying as I teach from home ad have to stop class to rest everything.
Mike
