Message 1 of 3
Fttp bvia powerline
Briefly, I have moved my router to another room, connected the ONT to a powerline adapter next to it. Router connected to mains via powerline adapter. All works fine but my router shows 59 Mbps down and I am on  900 Mbps !
I realise the router would get a substantial hit on its speed but hoped not as much as this!
I cannot run a Rj45 cable to the router so am experimenting with this setup.
If I drop my 900 contract to say 500 Mbps deal or less, will the speed at the router fall correspondingly, or get similar to now?
Also is there no improvements I can make using this new setup?
Many thanks,
John
2 REPLIES 2
Message 2 of 3
Re: Fttp bvia powerline
Dropping from 900 to 500 will make absolutely zero difference. Your powerline adapters and mains wiring are the limiting factor.
Message 3 of 3
Why can't you run an ethernet cable? Even a flat one?
