busterboy1
Expert
Message 51 of 161
Re: Full Fibre 900 WiFi speeds
@ihassan1
You will  not achieve those speeds on 2.4 buddy.
5ghz if you want to get anywhere near those speeds via WiFi.
@law94air
I also have the RT-AX88U and wanting a decent setup other than standard.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
ihassan1
Message 52 of 161
Hi @busterboy1
Thank for reply, what speeds are reasonable on 2.4ghz on a 80mbps DL on BT (thats what am paying for), on ethernet i get close like 76mbps DL and alway 18mbps UL!
On wifi I like 25-30mbps DL thats like a 60% drop even when am like a cm away from BT SH2.
Ive had like 6/7 BT openreach engineers, Qube and Halo Engineers in last few weeks.
Can't split the 2.4 and 5ghz on BT SH2 either, thats a pain due to their whole home mesh crappy system!
Also when it comes to wifi BT dont want to know! awful
They advertise all these and guarantees but its all worthless tbh
What would you suggest?....
law94air
Message 53 of 161
I bought the Asus RT AX 88U and didn't even bother with the SH2.  I split the bands and on 5G set to 160mhz AX mode I get 760Mpbs on my pc with a wireless WiFi 6 AX200 card and on my Samsung S10 I get 450Mpbs and on my ethernet connection I egt 1GBPS.
@jedpause managed to get 800 plus on his phone and was interested to know what he did on the router settings to achieve that.
I should also say that transferring blu Ray rips over WiFi to my Nas in the garage I get transfer speeds of 100MBps
ihassan1
Message 54 of 161
Am on 80mbps DL and 20mbps UL - I pay BT for
Hardware i get close to 76mbps DL and Awlays 18mpbs UL (thats never changes the UL) lol
On 2.4ghz whats reasonable to get on the above?
We have Samsung S10, S20, and other latest devices, laptops.
Ive even tested it with just 1 connection a smartphone or laptop or Apple Mac, same still get like 25-30mbps DL?
Surely that cant be right?
Ive changed wireless channels same!
Losing the will here its awful, ive literally tired everything I can think of.
On phone to BT thats 60th call last few weeks the person the BT cust service said youve got soo may times!!! Duhhhh
I hate calling BT tbh, they dnt help at all
law94air
Message 55 of 161
It all depends on what server you are connecting to when using the speed test.  Do a real world test and download macos file from apple and see what speeds you are getting.  But on a 70meg connection 30 to 40 Meg wireless download seems about right.  All depends on your signal strength and channel bandwidth on the 2.4ghz... Get fibre if you can afford it with an AX router... You won't regret it!
jedpause
Message 56 of 161
Hi @ihassan1 yes deffo 5GHz....
I will share my settings when I get the energy to do all the screen grabs 😂
Be a first rate version of yourself, not a second rate version of someone else
busterboy1
Expert
Message 57 of 161
@jedpause
I also look forward to that. Will help a lot of users.
Thank you. 🙂
jedpause
Message 58 of 161
Hi folks, I have not posted all the settings, those are generally default of have had not +/- bearing on my setup..
But I disabled QoS (Even on previous ASUS Routers as it resulted in appalling performance...) Nothing really special to be honest, No Game settings added/changed (my Son plays, I don't - he get's great speeds upstairs with low latency)...
To repeat, this is direct, no Smart Hub 2... and my speeds were with WiFi 6/AX devices. On AC clients, Apple etc. it was still much better - 700 MB/s plus average
Get your antennae setup properly too - Google best position, but I have them both pointing at devices (like a wand) and perpendicular (2 pointed/2 perpendicular) and whole house gets great speed and 500+ at back of the garden (LoS)
Ensure 160Mhz enabledEnsure 160Mhz enabledThis made the bigger jump on my devicesThis made the bigger jump on my devicesPretty Standard stuffPretty Standard stuff
busterboy1
Expert
Message 59 of 161
Little tweaks I have already learned. 🙂
Log in to Windows Command Prompt as administrator and type the following system32>netsh wlan show drivers   Enter to see your network types....
Here are mine.
Find your network adaptor and disable "Packet Coalescing" as shown here on my PC.
Below Packet Coalescing on the same page set 5Ghz as your preferred band then you know you are using the fastest.
Not much but it might help those wanting the best out of your 910mbps package. 🙂
law94air
Message 60 of 161
Thanks @jedpause   Tried your settings and got 560Mpbs so reverted back to my ones and was on 720Mpbs ...I suppose it all goes to show that the environment has a lot to do with the speed as well - walls and floors etc.
